<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="296" width="280"> <operator activated="true" class="generate_nominal_data" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="165"/> <operator activated="true" class="data_to_similarity" expanded="true" height="76" name="Data to Similarity" width="90" x="112" y="30"> <parameter key="measure_types" value="NominalMeasures"/> <parameter key="nominal_measure" value="JaccardSimilarity"/> </operator> <operator activated="true" class="k_means" expanded="true" height="76" name="Clustering" width="90" x="179" y="165"/> <connect from_op="Generate Nominal Data" from_port="output" to_op="Data to Similarity" to_port="example set"/> <connect from_op="Data to Similarity" from_port="similarity" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
