"Database connection."
Hi,
I am trying to connect RapidMiner with SQL server using sql server Authentication.But am not able to connect with database and always getting a message " Database error occurred: The TCP/IP connection to the host has failed. java.net.ConnectException: Connection refused: connect ".I have already enabled the driver in RM.This is my process.
<operator name="Root" class="Process" expanded="yes">
<operator name="DatabaseExampleSource" class="DatabaseExampleSource">
<parameter key="database_system" value="Microsoft SQL Server (Microsoft)"/>
<parameter key="database_url" value="jdbc:sqlserver://computer-647;databaseName=DataMart"/>
<parameter key="username" value="sa"/>
<parameter key="password" value="VNfe8QITNRw19hgf6f6UpA=="/>
<parameter key="query" value="select * from F_TFQ"/>
</operator>
</operator>
Thanks
Ratheesan
</operator>
</operator>
Thanks
Ratheesan
1 - 1 of
11
did you try to use the connection wizard? Does the test say ok? Does the data base drive show up in the Tools / Show Database driver overview?
Greetings,
Sebastian
