1 - 2 of
21
- To do this open your start menu and type "env var".
- Then in the menu that pops up select "environment variables".
- In the top half of that new menu select new and add the variable.
Hi Dhathresh,
It looks like EDEM is looking for the license file on your system but the environment variable is probably is not set to find the license.
Variable name: Altair_license_path
Value: C:\Program Files\Altair\2021\security\altair_lic.dat
This should solve your issue and get EDEM running for you.
Thank you, the issue has been resolved.
1 - 1 of
11
Hi Dhathresh,
Hi Dhathresh,
