Respected sir
Unable to solve for models in AOC 2021 due to licensing error for EDEM.
Please guide me
Attaching the error message in the snapshot
Hi Dhathresh,
It looks like EDEM is looking for the license file on your system but the environment variable is probably is not set to find the license.
Variable name: Altair_license_path
Value: C:\Program Files\Altair\2021\security\altair_lic.dat
This should solve your issue and get EDEM running for you.
Hi Dhathresh, It looks like EDEM is looking for the license file on your system but the environment variable is probably is not set to find the license. To do this open your start menu and type "env var". Then in the menu that pops up select "environment variables". In the top half of that new menu select new and add the variable. Variable name: Altair_license_path Value: C:\Program Files\Altair\2021\security\altair_lic.dat This should solve your issue and get EDEM running for you.
Thank you, the issue has been resolved.
