I am going on evaluating RapidMiner v5.0...
Today I was trying to work on a weka node: M5P.
I am trying to create a model tree for each loop on the values of "DistrictName".
The resulting trees are interesting, but the linear models have some problems.
All of them are in this format:
LM num: 1
Price_2009 =
+ (value1)with valuei different per each LM and DistrictName.
Do you know why it does not work?
Thank you, Armen
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Root">
<process expanded="true" height="539" width="1016">
<operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="45" y="120">
<parameter key="repository_entry" value="//NewLocalRepository/data2"/>
</operator>
<operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes (2)" width="90" x="179" y="120">
<parameter key="attribute_filter_type" value="subset"/>
<parameter key="attributes" value="ID|Price_2009|DistrictName|Flat|House|House_size_tot|House_size|House_ground|Basement_size|Year|WE|SN|dataset"/>
</operator>
<operator activated="true" class="numerical_to_binominal" expanded="true" height="76" name="Numerical to Binominal" width="90" x="313" y="120">
<parameter key="attributes" value="House|Flat"/>
</operator>
<operator activated="false" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="380" y="300">
<parameter key="name" value="Price_2009"/>
</operator>
<operator activated="false" class="discretize_by_bins" expanded="true" height="94" name="Discretize" width="90" x="514" y="300">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="Price_2009"/>
<parameter key="attributes" value="Price_2009"/>
<parameter key="number_of_bins" value="10"/>
</operator>
<operator activated="false" class="set_role" expanded="true" height="76" name="Set Role (2)" width="90" x="648" y="300">
<parameter key="target_role" value="label"/>
</operator>
<operator activated="true" class="loop_values" expanded="true" height="112" name="ValueIterator" width="90" x="715" y="120">
<parameter key="attribute" value="DistrictName"/>
<process expanded="true" height="484" width="1016">
<operator activated="true" class="filter_examples" expanded="true" height="76" name="ExampleFilter" width="90" x="45" y="120">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="DistrictName = %{loop_value}"/>
</operator>
<operator activated="true" class="filter_examples" expanded="true" height="76" name="Filter Examples" width="90" x="179" y="120">
<parameter key="parameter_string" value="dataset = train"/>
</operator>
<operator activated="true" class="filter_examples" expanded="true" height="76" name="Filter Examples (2)" width="90" x="447" y="210">
<parameter key="parameter_string" value="dataset = test"/>
</operator>
<operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="380" y="75">
<parameter key="attributes" value="Year|House_size_tot|House_size|Basement_size|House_ground|SN|WE|Price_2009|ID"/>
</operator>
<operator activated="true" class="W-M5P" expanded="true" height="76" name="W-M5P" width="90" x="581" y="30">
<parameter key="R" value="true"/>
<parameter key="L" value="true"/>
</operator>
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model (XY)" width="90" x="715" y="120">
</operator>
<operator activated="true" class="performance" expanded="true" height="76" name="Performance (2)" width="90" x="916" y="30"/>
<connect from_port="example set" to_op="ExampleFilter" to_port="example set input"/>
<connect from_op="ExampleFilter" from_port="example set output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="original" to_op="Filter Examples (2)" to_port="example set input"/>
<connect from_op="Filter Examples (2)" from_port="example set output" to_op="Apply Model (XY)" to_port="unlabelled data"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="W-M5P" to_port="training set"/>
<connect from_op="W-M5P" from_port="model" to_op="Apply Model (XY)" to_port="model"/>
<connect from_op="Apply Model (XY)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
<connect from_op="Apply Model (XY)" from_port="model" to_port="out 3"/>
<connect from_op="Performance (2)" from_port="performance" to_port="out 1"/>
<connect from_op="Performance (2)" from_port="example set" to_port="out 2"/>
<portSpacing port="source_example set" spacing="90"/>
<portSpacing port="sink_out 1" spacing="0"/>
<portSpacing port="sink_out 2" spacing="0"/>
<portSpacing port="sink_out 3" spacing="72"/>
<portSpacing port="sink_out 4" spacing="54"/>
</process>
</operator>
<operator activated="true" class="append" expanded="true" height="76" name="ExampleSetMerge (XY)" width="90" x="916" y="120"/>
<connect from_op="Retrieve" from_port="output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/>
<connect from_op="Numerical to Binominal" from_port="example set output" to_op="ValueIterator" to_port="example set"/>
<connect from_op="ValueIterator" from_port="out 1" to_port="result 1"/>
<connect from_op="ValueIterator" from_port="out 2" to_op="ExampleSetMerge (XY)" to_port="example set 1"/>
<connect from_op="ValueIterator" from_port="out 3" to_port="result 2"/>
<connect from_op="ExampleSetMerge (XY)" from_port="merged set" to_port="result 3"/>
<portSpacing port="sink_result 1" spacing="18"/>
<portSpacing port="sink_result 2" spacing="126"/>
<portSpacing port="sink_result 3" spacing="90"/>
<portSpacing port="sink_result 4" spacing="0"/>
</process>
</operator>
</process>
