Altair RISE
Nominate Yourself Now!
"Problem with FeatureExtraction (VISTA, Java 1.6.16)"
User: "skarab"
New Altair Community Member
Updated by Jocelyn
Could somebody explain me how to use FeatureExtraction, because it does not work for me...
Here is my code:
<operator name="FeatureExtraction" class="FeatureExtraction" breakpoints="within,after">
                          <list key="texts">
                            <parameter key="tmp_dir" value="c:\tmp\tmp%{file_name}"/>
                          </list>
                          <parameter key="default_content_type" value="text/html"/>
                          <parameter key="default_content_encoding" value="UTF-8"/>
                          <parameter key="default_content_language" value="pl"/>
                          <parameter key="use_content_attributes" value="true"/>
                          <parameter key="id_attribute_type" value="number"/>
                          <list key="attributes">
                            <parameter key="cala_strona" value="//h:div/h:div/text()"/>
                            <parameter key="prezentacja" value="//h:div/text()"/>
                            <parameter key="all" value="&quot;.*&quot;"/>
                            <parameter key="root_www" value="/h:html/text()"/>
                            <parameter key="result_text" value="//h:div[class=&quot;result_txt&quot;]"/>
                            <parameter key="result" value="/h:html/h:body/h:div/h:div[2]/h:div[3]/h:div/h:div[3]/h:div/h:ul/hi:li[2]/h:div[2]/text()"/>
                          </list>
                          <list key="namespaces">
                          </list>
                      </operator>
I am using it in my plan, which extracts data for analysis from HTML page using XPATH:
1 - 3 of 31
    User: "skarab"
    OP
    Here is my complete plan, which I use to traverse directories, read html files, clean them, replace DOCTYPE declaration, and finally, extract data fields:
    <?xml version="1.0" encoding="windows-1252"?>
    <process version="4.5">
     <operator name="Root" class="Process" expanded="yes">
         <parameter key="logverbosity" value="status"/>
         <parameter key="random_seed" value="2001"/>
         <parameter key="send_mail" value="never"/>
         <parameter key="process_duration_for_mail" value="30"/>
         <parameter key="encoding" value="SYSTEM"/>
         <operator name="DirsIter" class="FileIterator" expanded="yes">
             <parameter key="directory" value="C:\input\htmls\"/>
             <parameter key="file_name_macro" value="file_name"/>
             <parameter key="file_path_macro" value="file_path"/>
             <parameter key="parent_path_macro" value="parent_path"/>
             <parameter key="recursive" value="false"/>
             <parameter key="iterate_over_files" value="false"/>
             <parameter key="iterate_over_subdirs" value="true"/>
             <operator name="FileIterator" class="FileIterator" expanded="yes">
                 <parameter key="directory" value="%{file_path}"/>
                 <parameter key="iterate_over_files" value="true"/>
                 <parameter key="iterate_over_subdirs" value="false"/>
                 <operator name="Cleaning" class="OperatorChain" expanded="yes">
                     <operator name="TextObjectLoader" class="TextObjectLoader">
                         <parameter key="file" value="%{file_path}"/>
                     </operator>
                     <operator name="TextSegmenter" class="TextSegmenter" expanded="yes">
                         <parameter key="start_regex" value="&lt;!DOCTYPE html PUBLIC [^&gt;]*&gt;"/>
                         <parameter key="end_regex" value="&lt;/html&gt;"/>
                         <operator name="TextCleaner" class="TextCleaner">
                             <parameter key="deletion_regex" value="&lt;!DOCTYPE html PUBLIC [^&gt;]*&gt;"/>
                         </operator>
                         <operator name="TextObject2ExampleSet" class="TextObject2ExampleSet">
                             <parameter key="keep_text_object" value="true"/>
                             <parameter key="text_attribute" value="my_doc_text"/>
                             <parameter key="label_attribute" value="my_doc_label"/>
                         </operator>
                         <operator name="ValueIterator" class="ValueIterator" expanded="yes">
                             <parameter key="attribute" value="my_doc_text"/>
                             <parameter key="iteration_macro" value="loop_value"/>
                             <operator name="SingleTextObjectInput" class="SingleTextObjectInput">
                                 <parameter key="text" value="&lt;!DOCTYPE html PUBLIC &quot;-//W3C//DTD XHTML 1.0 Transitional//EN&quot; &quot;file:///C:/workspace-rapidminer/xhtml1-transitional.dtd&quot; &gt;%{loop_value}"/>
                             </operator>
                         </operator>
                         <operator name="TextObjectWriter" class="TextObjectWriter">
                             <parameter key="file" value="c:\tmp\tmp%{file_name}\%{file_name}"/>
                             <parameter key="overwrite" value="true"/>
                         </operator>
                         <operator name="IOConsumer ExampleSet" class="IOConsumer">
                             <parameter key="io_object" value="ExampleSet"/>
                             <parameter key="deletion_type" value="delete_all"/>
                             <parameter key="delete_which" value="1"/>
                             <parameter key="except" value="1"/>
                         </operator>
                         <operator name="IOConsumer TextObject" class="IOConsumer">
                             <parameter key="io_object" value="TextObject"/>
                         </operator>
                             <list key="texts">
                             </list>
                               <parameter key="a_data" value="//h:div/h:div/text()"/>
                               <parameter key="text_in_divs" value="//h:div/text()"/>
                             </list>
                             </list>
                         </operator>
                         <operator name="IOObjectWriter" class="IOObjectWriter">
                             <parameter key="object_file" value="c:\tmp\result%{file_name}\%{file_name}_res"/>
                             <parameter key="write_which" value="1"/>
                             <parameter key="output_type" value="XML"/>
                             <parameter key="continue_on_error" value="true"/>
                         </operator>
                     </operator>
                 </operator>
                 <operator name="Extraction" class="OperatorChain" expanded="yes">
                 </operator>
             </operator>
         </operator>
     </operator>
    </process>
    User: "land"
    Hi,
    what's the error message? Perhaps your XPath expression is wrong? Did you take a look into the Operator description?
    Greetings,
      Sebastian
    User: "skarab"
    OP
    The problem is solved... I had a  mistake (stupid ;) ) in namespace mapping of FeatureExtractor...
    <FeatureExtractor>
                              <parameter key="x" value="http://www.w3.org/1999/xhtml"/>
    </list>
    </FeatureExtractor>
    and...
            <parameter key="abc" value="//x:div/x:div/text()"/>
    works ;D
