"Problem with FeatureExtraction (VISTA, Java 1.6.16)"
skarab
Could somebody explain me how to use FeatureExtraction, because it does not work for me...
Here is my code:
<operator name="FeatureExtraction" class="FeatureExtraction" breakpoints="within,after">
<list key="texts">
<parameter key="tmp_dir" value="c:\tmp\tmp%{file_name}"/>
</list>
<parameter key="default_content_type" value="text/html"/>
<parameter key="default_content_encoding" value="UTF-8"/>
<parameter key="default_content_language" value="pl"/>
<parameter key="use_content_attributes" value="true"/>
<parameter key="id_attribute_type" value="number"/>
<list key="attributes">
<parameter key="cala_strona" value="//h:div/h:div/text()"/>
<parameter key="prezentacja" value="//h:div/text()"/>
<parameter key="all" value="".*""/>
<parameter key="root_www" value="/h:html/text()"/>
<parameter key="result_text" value="//h:div[class="result_txt"]"/>
<parameter key="result" value="/h:html/h:body/h:div/h:div[2]/h:div[3]/h:div/h:div[3]/h:div/h:ul/hi:li[2]/h:div[2]/text()"/>
</list>
<list key="namespaces">
</list>
I am using it in my plan, which extracts data for analysis from HTML page using XPATH:
Java
skarab
Here is my complete plan, which I use to traverse directories, read html files, clean them, replace DOCTYPE declaration, and finally, extract data fields:
<?xml version="1.0" encoding="windows-1252"?>
<process version="4.5">
<parameter key="logverbosity" value="status"/>
<operator name="DirsIter" class="FileIterator" expanded="yes">
<parameter key="directory" value="C:\input\htmls\"/>
<parameter key="file_name_macro" value="file_name"/>
<parameter key="file_path_macro" value="file_path"/>
<parameter key="parent_path_macro" value="parent_path"/>
<parameter key="recursive" value="false"/>
<parameter key="iterate_over_files" value="false"/>
<parameter key="iterate_over_subdirs" value="true"/>
<operator name="FileIterator" class="FileIterator" expanded="yes">
<parameter key="directory" value="%{file_path}"/>
<parameter key="iterate_over_files" value="true"/>
<parameter key="iterate_over_subdirs" value="false"/>
<operator name="Cleaning" class="OperatorChain" expanded="yes">
<operator name="TextObjectLoader" class="TextObjectLoader">
<parameter key="file" value="%{file_path}"/>
<operator name="TextSegmenter" class="TextSegmenter" expanded="yes">
<parameter key="start_regex" value="<!DOCTYPE html PUBLIC [^>]*>"/>
<parameter key="end_regex" value="</html>"/>
<operator name="TextCleaner" class="TextCleaner">
<parameter key="deletion_regex" value="<!DOCTYPE html PUBLIC [^>]*>"/>
<operator name="TextObject2ExampleSet" class="TextObject2ExampleSet">
<parameter key="keep_text_object" value="true"/>
<parameter key="text_attribute" value="my_doc_text"/>
<parameter key="label_attribute" value="my_doc_label"/>
<operator name="ValueIterator" class="ValueIterator" expanded="yes">
<parameter key="attribute" value="my_doc_text"/>
<parameter key="iteration_macro" value="loop_value"/>
<operator name="SingleTextObjectInput" class="SingleTextObjectInput">
<parameter key="text" value="<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "file:///C:/workspace-rapidminer/xhtml1-transitional.dtd" >%{loop_value}"/>
<operator name="TextObjectWriter" class="TextObjectWriter">
<parameter key="file" value="c:\tmp\tmp%{file_name}\%{file_name}"/>
<parameter key="overwrite" value="true"/>
<operator name="IOConsumer ExampleSet" class="IOConsumer">
<parameter key="io_object" value="ExampleSet"/>
<parameter key="deletion_type" value="delete_all"/>
<parameter key="delete_which" value="1"/>
<parameter key="except" value="1"/>
<operator name="IOConsumer TextObject" class="IOConsumer">
<parameter key="io_object" value="TextObject"/>
<list key="texts">
</list>
<parameter key="a_data" value="//h:div/h:div/text()"/>
<parameter key="text_in_divs" value="//h:div/text()"/>
</list>
</list>
<operator name="IOObjectWriter" class="IOObjectWriter">
<parameter key="object_file" value="c:\tmp\result%{file_name}\%{file_name}_res"/>
<parameter key="write_which" value="1"/>
<parameter key="output_type" value="XML"/>
<parameter key="continue_on_error" value="true"/>
<operator name="Extraction" class="OperatorChain" expanded="yes">
</process>
land
what's the error message? Perhaps your XPath expression is wrong? Did you take a look into the Operator description?
Greetings,
Sebastian
skarab
The problem is solved... I had a mistake (stupid
) in namespace mapping of FeatureExtractor...
<FeatureExtractor>
<parameter key="x" value="
http://www.w3.org/1999/xhtml
</list>
</FeatureExtractor>
and...
<parameter key="abc" value="//x:div/x:div/text()"/>
works ;D
