🎉Community Raffle - Win $25
Join and Win
"Nested macros"
User: "cherokee"
New Altair Community Member
Updated by Jocelyn
Hi!
I have an example set with different attributes and a class. For all regular attributes I want to calculate the average of examples labled false. Then I want to use this averages and calculate for every example the difference to this average.
I planned to use a feature iterator (over all false examples) to calculate all averages and store them in macros. Then i wanted to use another feature iterator (over all examples) to calculate the difference in an AttributeConstruction:
<operator name="Calculate Averages" class="OperatorChain" expanded="no">
    <operator name="Work on copy" class="IOMultiplier">
        <parameter key="io_object" value="ExampleSet"/>
    </operator>
    <operator name="Only non-pain" class="ExampleFilter">
      <parameter key="condition_class" value="attribute_value_filter"/>
      <parameter key="parameter_string" value="pain=no"/>
    </operator>
    <operator name="For All Distances and Angles" class="FeatureIterator" expanded="no">
        <parameter key="filter" value="dist.*|angle.*"/>
        <operator name="Calculate Average" class="DataMacroDefinition">
            <parameter key="macro" value="avg_%{loop_feature}"/>
            <parameter key="macro_type" value="statistics"/>
            <parameter key="attribute_name" value="%{loop_feature}"/>
        </operator>
    </operator>
    <operator name="Delete Copy" class="IOConsumer">
                <parameter key="deletion_type" value="delete_one"/>
      </operator>
</operator>
<operator name="Calculate Relations" class="OperatorChain" expanded="yes">
    <operator name="For All Distances and Angles (2)" class="FeatureIterator" expanded="yes">
        <parameter key="filter" value="whatever.*"/>
        <parameter key="work_on_input" value="false"/>
            <operator name="AttributeConstruction" class="AttributeConstruction">
                <list key="function_descriptions">
                      <parameter key="%{loop_feature}_Quotient" value="%{avg_%{loop_feature}}"/>
                </list>
              </operator>
      </operator>
</operator>
The problem is this line:
I get an UserError: SyntaxError. By now I know that is is obviously not possible to have an macro in a macro name. How can I come over this problem?
I would also be happy about a totally different solution. (Please consider that I'm dealing with about 4000 attributes which are not known jet. So assigning individual names is not possible).
1 - 1 of 11
    User: "land"
    Hi,
    here's a total different solution :) This way it should work, if you adapt the following process onto your needs.
    <operator name="Root" class="Process" expanded="yes">
      <operator name="ExampleSetGenerator" class="ExampleSetGenerator">
          <parameter key="target_function"    value="sum"/>
      </operator>
      <operator name="FeatureIterator" class="FeatureIterator" expanded="yes">
          <operator name="Aggregation" class="Aggregation">
              <list key="aggregation_attributes">
                <parameter key="%{loop_feature}"    value="average"/>
              </list>
          </operator>
          <operator name="DataMacroDefinition" class="DataMacroDefinition">
              <parameter key="macro"    value="current_average"/>
              <parameter key="macro_type"    value="data_value"/>
              <parameter key="attribute_name"    value="average(%{loop_feature})"/>
              <parameter key="example_index"    value="1"/>
          </operator>
          <operator name="IOConsumer" class="IOConsumer">
          </operator>
                <parameter key="norm_%{loop_feature}"    value="%{loop_feature} - %{current_average}"/>
              </list>
          </operator>
      </operator>
    </operator>
    Greetings,
      Sebastian
