Hi!
I have an example set with different attributes and a class. For all regular attributes I want to calculate the average of examples labled false. Then I want to use this averages and calculate for every example the difference to this average.
I planned to use a feature iterator (over all false examples) to calculate all averages and store them in macros. Then i wanted to use another feature iterator (over all examples) to calculate the difference in an AttributeConstruction:
<operator name="Calculate Averages" class="OperatorChain" expanded="no">
<operator name="Work on copy" class="IOMultiplier">
<parameter key="io_object" value="ExampleSet"/>
<operator name="Only non-pain" class="ExampleFilter">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="pain=no"/>
<operator name="For All Distances and Angles" class="FeatureIterator" expanded="no">
<parameter key="filter" value="dist.*|angle.*"/>
<operator name="Calculate Average" class="DataMacroDefinition">
<parameter key="macro" value="avg_%{loop_feature}"/>
<parameter key="macro_type" value="statistics"/>
<parameter key="attribute_name" value="%{loop_feature}"/>
<operator name="Delete Copy" class="IOConsumer">
<parameter key="deletion_type" value="delete_one"/>
<operator name="Calculate Relations" class="OperatorChain" expanded="yes">
<operator name="For All Distances and Angles (2)" class="FeatureIterator" expanded="yes">
<parameter key="filter" value="whatever.*"/>
<parameter key="work_on_input" value="false"/>
<operator name="AttributeConstruction" class="AttributeConstruction">
<parameter key="%{loop_feature}_Quotient" value="%{avg_%{loop_feature}}"/>
</list>
The problem is this line:
<parameter key="%{loop_feature}_Quotient" value="%{avg_%{loop_feature}}"/> I get an UserError: SyntaxError. By now I know that is is obviously not possible to have an macro in a macro name. How can I come over this problem?
I would also be happy about a totally different solution. (Please consider that I'm dealing with about 4000 attributes which are not known jet. So assigning individual names is not possible).
