How to use TextInput operator
Hi,
I am running some test and I want to use TextInput operaotr in my code so can I read a bunch of text files(which is in a specific location) in order to do the textclassifiction. Can some one please show how to use the TextInput operator in my code so I can read some text files and get the classification (I am new in programming).
My test code:===================================
import java.io.File;
import java.io.IOException;
import com.rapidminer.RapidMiner;
import com.rapidminer.example.Example;
import com.rapidminer.example.ExampleSet;
import com.rapidminer.operator.IOContainer;
import com.rapidminer.operator.Model;
import com.rapidminer.operator.Operator;
import com.rapidminer.operator.OperatorChain;
import com.rapidminer.operator.OperatorCreationException;
import com.rapidminer.operator.OperatorException;
import com.rapidminer.tools.OperatorService;
public class tect {
private OperatorChain wvtoolOperator;
private Operator modelApplier;
private Model model;
public tect(File modelFile, File wordListFile)
throws IOException, OperatorCreationException, OperatorException {
String path="C:\\Program Files\\Rapid-I\\RapidMiner-4.3\\";
System.setProperty("rapidminer.home",path );
//String pluginDirString = new File("rapidminer.home","C:\\Documents and Settings\\ssubpol\\Desktop\\WorkFile\\rapidminertest\\lib").getAbsolutePath();
// System.setProperty(RapidMiner.PROPERTY_RAPIDMINER_INIT_PLUGINS_LOCATION, pluginDirString);
//String pluginDirString=new File ();
RapidMiner.init(false, false, false, true);
// Create the text input operator and set the path to the word list you stored using Rapid Miner
// As there is only a single text, we use the SingleTextInput operator
wvtoolOperator = (OperatorChain) OperatorService
.createOperator("SingleTextInput");
wvtoolOperator.setParameter("input_word_list", wordListFile
.getAbsolutePath());
// Add additional processing steps.
// Note the setup must be same as the one you used when creating the classification model
wvtoolOperator.addOperator(OperatorService.createOperator("StringTokenizer"));
wvtoolOperator.addOperator(OperatorService.createOperator("EnglishStopwordFilter"));
wvtoolOperator.addOperator(OperatorService.createOperator("TokenLengthFilter"));
wvtoolOperator.addOperator(OperatorService.createOperator("PorterStemmer"));
// Create the model applier
modelApplier = OperatorService.createOperator("ModelApplier");
// Load the model into a field of the class
Operator modelLoader = OperatorService.createOperator("ModelLoader");
modelLoader.setParameter("model_file", modelFile.getAbsolutePath());
IOContainer container = modelLoader.apply(new IOContainer());
model = container.get(Model.class);
public String apply(String text) throws OperatorException {
// Set the text
wvtoolOperator.setParameter("text", text);
// Call the text input operator
IOContainer container = wvtoolOperator.apply(new IOContainer(model));
// Call the model applier (the model was added already before calling the text input)
container = modelApplier.apply(container);
// Obtain the example set from the io container. It contains only a single example with our text in it.
ExampleSet eset = container.get(ExampleSet.class);
Example e = eset.iterator().next();
// Compare the predicted label with the positive label
return eset.getAttributes().getPredictedLabel().getMapping().mapIndex((int) e.getPredictedLabel());
public static void main(String args[]) throws Exception {
// Create a text classifier
//System.setProperty("rapidminer.home", "C:\\Documents and Settings\\ssaha\\Desktop\\Workstation2\\rapidminertest\\data\\");
tect tr = new tect(
new File(
"C:\\Documents and Settings\\ssaha\\Desktop\\Workstation2\\rapidminertest\\data\\mod2.mod"),
new File(
"C:\\Documents and Settings\\ssaha\\Desktop\\Workstation2\\rapidminertest\\data\\wordlist.list"));
// Call the classifier with texts
System.out.println("Test1:" + tr.apply("sdjklfjasd'jgma'sd jd'sjf'sjk"));
System.out.println("Test2:" + tr.apply("workstation intel switch"));
System.out.println("Test3:" + tr.apply("workstation exploit cinninati"));
Please help me out, I am stuck!!!!!! help....
public class tect {
// Set the text
tect tr = new tect(
new File(
new File(
1 - 4 of
41
- Read the tutorial.pdf (also available at rapidminer's page at sourceforge), especially "Extending RapidMiner" and "Integrating RapidMiner in your application"
- Restructure your code
- ask again if you still got problems
hay.....can any one help me out in this par asap...I am stuck here....please give me some direction...
Hello sasss52
I do not know much about text mining, but there are some things mixed up in your code, so I suggest...
Steffen
Steffen
