Calculation by Groups
Shubha
Shubha New Altair Community Member
edited November 2024 in Community Q&A
Hi,
This is a newbie's question...I have a data which looks like the below:
Group Value
1 78
1 64
1 75
2 66
2 54
2 72
2 77
3 57
3 59
3 61
Now, i want to do a calculation by groups. And this calculation is ABS("Value" - Group Average). The output datafile should look like the below:
Group Value Result
1 78 5.666666667
1 64 8.333333333
1 75 2.666666667
2 66 1.25
2 54 13.25
2 72 4.75
2 77 9.75
3 57 2
3 59 0
3 61 2
This is exactly group processing. How do we do this in Rapid Miner?
Many thanks for your help,
Shubha
Welcome!
Answers
  • Shubha
    Shubha wrote:
    Hi,
    Group Value
    1 78
    1 64
    1 75
    2 66
    2 54
    2 72
    2 77
    3 57
    3 59
    3 61
    Group Value Result
    1 78 5.666666667
    1 64 8.333333333
    1 75 2.666666667
    2 66 1.25
    2 54 13.25
    2 72 4.75
    2 77 9.75
    3 57 2
    3 59 0
    3 61 2
    Shubha
    Does the "Attribute Constructor" or the "ValueSubgroupIterator" help me with this respect?
  • Shubha
    Does this take too many steps to do in Rapidminer?
    BR, Shubha
  • IngoRM
    IngoRM New Altair Community Member
    Hi,
    it's actually pretty simple:
    <operator name="Root" class="Process" expanded="yes">
        <operator name="Generate Data" class="OperatorChain" expanded="no">
            <operator name="ExampleSetGenerator" class="ExampleSetGenerator">
                <parameter key="target_function" value="sum"/>
                <parameter key="number_examples" value="12"/>
                <parameter key="number_of_attributes" value="2"/>
            </operator>
            <operator name="AttributeFilter" class="AttributeFilter">
                <parameter key="condition_class" value="attribute_name_filter"/>
                <parameter key="parameter_string" value="label"/>
                <parameter key="invert_filter" value="true"/>
                <parameter key="apply_on_special" value="true"/>
            </operator>
            <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes">
                <parameter key="attribute_name_regex" value="att1"/>
                <operator name="FrequencyDiscretization" class="FrequencyDiscretization">
                    <parameter key="number_of_bins" value="3"/>
                    <parameter key="range_name_type" value="short"/>
                </operator>
            </operator>
            <operator name="Sorting" class="Sorting">
                <parameter key="attribute_name" value="att1"/>
            </operator>
        </operator>
        <operator name="ValueIterator" class="ValueIterator" expanded="yes">
            <parameter key="attribute" value="att1"/>
            <operator name="ExampleFilter" class="ExampleFilter">
                <parameter key="condition_class" value="attribute_value_filter"/>
                <parameter key="parameter_string" value="att1 = %{loop_value}"/>
            </operator>
            <operator name="Aggregation" class="Aggregation">
                <list key="aggregation_attributes">
                  <parameter key="att2" value="average"/>
                </list>
            </operator>
            <operator name="DataMacroDefinition" class="DataMacroDefinition">
                <parameter key="macro" value="current_average"/>
                <parameter key="macro_type" value="data_value"/>
                <parameter key="attribute_name" value="average(att2)"/>
                <parameter key="example_index" value="1"/>
            </operator>
            <operator name="IOConsumer" class="IOConsumer">
                <parameter key="io_object" value="ExampleSet"/>
                <parameter key="deletion_type" value="delete_one"/>
            </operator>
            <operator name="AttributeConstruction" class="AttributeConstruction">
                <list key="function_descriptions">
                  <parameter key="att2_abs_avg" value="abs(att2 - %{current_average})"/>
                </list>
            </operator>
        </operator>
        <operator name="ExampleSetMerge" class="ExampleSetMerge">
        </operator>
    </operator>
    Please note that the first chain is only used for generating data like you have described. The ValueIterator together with the aggregation and the merge do the trick.
    All the best,
    Ingo
  • Shubha
    Thank you very much Ingo...
    A question is:
    Can I do this without splitting the data into 3 data parts( according to the groups)...
  • IngoRM
    Hi,
    with a different (and more complex) setup for RM 4.4 (coming this week): yes, it would also be possible without "dividing" the data. But what's wrong with it? Actually, the different data parts are only views on the same data set and therefore should be no problem at all.
    Cheers,
    Ingo
  • Shubha
    Oh, is it? They are the views and not exactly 3 different data being generated? And so, it would not consume the memory space for my large data?
    Thanks,
    Shubha
  • Shubha
    Hi,
    One last question,
    While I join daasets in the end by "ExampleSetMerge", the group order is changed. How to get back the original group order while merging? Is there a way to reverse the order number of the 3 different datasets generated?
    Thanks,
    Shubha
  • IngoRM
    Well, a little bit of digging around yourself would probably not hurt: in the process I sent to you, there already was a Sorting operator at the end of the data generation process. Use another one directly after the merge.
    Cheers,
    Ingo
  • Shubha
    Thanks Ingo... Sorting is fine... But actually my problem is,
    We have the generated split datasets. While joining itself, can we join in the order? Or atleast in the descending order? This would help another problem of mine...
    Thanks, Shubha
Welcome!
Welcome!
