Shubha wrote:Hi,This is a newbie's question...I have a data which looks like the below:Group Value1 781 641 752 662 542 722 773 573 593 61Now, i want to do a calculation by groups. And this calculation is ABS("Value" - Group Average). The output datafile should look like the below:Group Value Result1 78 5.6666666671 64 8.3333333331 75 2.6666666672 66 1.252 54 13.252 72 4.752 77 9.753 57 23 59 03 61 2This is exactly group processing. How do we do this in Rapid Miner?Many thanks for your help,Shubha
<operator name="Root" class="Process" expanded="yes"> <operator name="Generate Data" class="OperatorChain" expanded="no"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="sum"/> <parameter key="number_examples" value="12"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator name="AttributeFilter" class="AttributeFilter"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="parameter_string" value="label"/> <parameter key="invert_filter" value="true"/> <parameter key="apply_on_special" value="true"/> </operator> <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="attribute_name_regex" value="att1"/> <operator name="FrequencyDiscretization" class="FrequencyDiscretization"> <parameter key="number_of_bins" value="3"/> <parameter key="range_name_type" value="short"/> </operator> </operator> <operator name="Sorting" class="Sorting"> <parameter key="attribute_name" value="att1"/> </operator> </operator> <operator name="ValueIterator" class="ValueIterator" expanded="yes"> <parameter key="attribute" value="att1"/> <operator name="ExampleFilter" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="att1 = %{loop_value}"/> </operator> <operator name="Aggregation" class="Aggregation"> <list key="aggregation_attributes"> <parameter key="att2" value="average"/> </list> </operator> <operator name="DataMacroDefinition" class="DataMacroDefinition"> <parameter key="macro" value="current_average"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="average(att2)"/> <parameter key="example_index" value="1"/> </operator> <operator name="IOConsumer" class="IOConsumer"> <parameter key="io_object" value="ExampleSet"/> <parameter key="deletion_type" value="delete_one"/> </operator> <operator name="AttributeConstruction" class="AttributeConstruction"> <list key="function_descriptions"> <parameter key="att2_abs_avg" value="abs(att2 - %{current_average})"/> </list> </operator> </operator> <operator name="ExampleSetMerge" class="ExampleSetMerge"> </operator></operator>
