"OperatorSelector does not work with Macro Definition"
Hello
Using OperatorSelector with MacroDefiniton I got an NumberFormatError. Diving into the code I found that you have fixed the problem of Integer-Parameters-do-not-use-macros, but not problem of the MacroHandler itself: (i.e. it also occurs in the Zaniah Branch)
Since OperatorSelector try to access the macro BEFORE the process is executed, it gets an error since this macros have not been defined yet. At this step, MacroHandler has only access to predefined macros, the Map "macroMap" is empty. I choose not to add a note in the bugtracker, because this is a quite architectural (does this word exist) problem which may affect other operators, too.
affected methods of OperatorSelector
regards,
Steffen
- getInputClasses()
- getOutputClasses()
- getInnerOperatorCondition()
regards,
Steffen
