🎉Community Raffle - Win $25
Join and Win
Using StringTextInput
User: "Legacy User"
New Altair Community Member
Updated by Jocelyn
Hi,
I was wondering if you can provide an example as to how I should use the StringTextInput, as I currently dump my texts to file and re-load them with TextInputOperator. I just don't know how to create an ExampleSet containing my strings for StringTextInput: Do I have to do something complex like the tutorial PDF shows on ExampleSet creation (with a method providing access to a table and all)? Isn't there just some way to send it a String[] containing my texts? (SingleTextInput won't do because I have to use a learner later on all texts at once. I successfully use SingleTextInput during testing).
Thanks a lot,
Nimrod
1 - 1 of 11
    User: "IngoRM"
    Hi,
    maybe this thread helps to get a starting point:
    http://rapid-i.com/rapidforum/index.php/topic,19.0.html
    Using the StringTextInput is actually pretty easy. Just make sure you texts are stored in a column of your database and apply the operator to it (it might be that you have to activate "filter_nominal").
    Cheers,
    Ingo
