Dear,
I need urgent help, i should to extract an applicattion from rapidminer. I just to extracted the class that i need, but i can not run application, because i dont know, how can i pass the file and the parameters, which class is the main class??
thank very much
Isis
I have moved this topic from Chit Chat to Development and also replaced the headline by a non-shouting variant.
About your request: you should have a look into the written tutorial, Chapter 7. Here it is described how you can include (parts of) RapidMiner into own applications. If you have more concrete questions then, you can surely write back and ask for concrete help. If this is professional work, I would suggest to rely on the services of Rapid-I, by the way.
Cheers,
Ingo
