RapidMiner jar file cannot be accessed
shk721
shk721 New Altair Community Member
edited November 2024 in Community Q&A
Hi everyoene;
i been trying to write down integerate my produced model in java application . However , i don't know what is wrong with RapidMiner.jar file
i put in the right class path and i add it to the library but stil , it doesn't work.
can anyone help me to figure out the reason for this.
cheers;
Hassan
Welcome!
Answers
  • IngoRM
    IngoRM New Altair Community Member
    Hi,
    sorry but I would need a lot more information.  What exactly do you want to achieve? What did you try? What went wrong? Which versions? Etc. Everything  ;)
    Cheers,
    Ingo
  • shk721
    i am just in the beggining . just  i want to examine the example given for integerating rapidminer result model  in an application
    the Rapidminer which could be accessed during compiling stage taken from the (lib  folder ) in rapidminer folder that is generated form insalling
    rapidminer version 4.2
    so, i don't know if  i should take this jar file from somewhere else and if it is ok what reason can protect it from being accessed .
    thanks Ingo for your gret support for this wondeful tool.
    cheers;
    hassan
  • steffen
    steffen New Altair Community Member
    Hello
    Using the rapidminer.jar in from the lib-folder should work. However, some RapidMiner Operators need additional libraries which should be in the classpath, too.
    Could you be so kind to post the error message ?
    greetings
    Steffen
Welcome!
Welcome!
