Plugins not visible
Hello Guys,
Earlier i had developed a plugin for some image processing. Now I have developed a few more image processing operators and I am trying to develop a plugin for the same. I did followed exactly the same procedure which i had followed the last time. The code gets compiled properly and a jar file is also created. After copying the jar file into the plugin folder of rapidminer on starting rapidminer i dont get any kind of error but i am unable to see my operators in the rapidminer window. Could anyone plz let me the solution or where i could be going wrong?
Thanks and Regards
Thanks and Regards
1 - 6 of
61
I am not using the CVS.
I am extending the Rapidminer.
I have a class which extends operator and a result class extends ResultObjectAdapter.
I have given bodies to the necessary methods in the above classes.
Then i am using build.xml to create a Jar file and adding operator.xml file to the Mani-Fest folder in created jar file.
After this i copy the created jar file into the plugins folder and trying to run rapidminer.
It opens successfully but I am unable to see my operators.
@naharvikas:
As Steffen has pointed out: for plugins which should be combined with the latest CVS version (and also with future versions), it is necessary to add another entry in the manifest file. Please follow the instructions given in the link
http://rapid-i.com/rapidforum/index.php/topic,58.0.html
This should do the trick. A complete manifest should then look like this (taken from the Text plugin):
Hope that helps,
Ingo
The last line (RapidMiner-Type: RapidMiner_Plugin) is new and indicates that this is a RM plugin. Just put the contents given above in a file MANIFEST.MF and place it in the META-INF folder of your jar file.
Manifest-Version: 1.0
Ant-Version: Apache Ant 1.7.0
Created-By: 10.0-b22 (Sun Microsystems Inc.)
Implementation-Vendor: Rapid-I
Implementation-Title: Text Plugin
Implementation-URL: http://www.rapid-i.com
Implementation-Version: 4.1
RapidMiner-Version: 4.1
Hope that helps,
Ingo
Do you use the CVS-Version ? If this is true, did you recognize this: http://rapid-i.com/rapidforum/index.php/topic,58.0.html
If this not help... Maybe you can tell us, what you did exactly
greetings
Steffen
