🎉Community Raffle - Win $25
Join and Win
EDEM API - Contact Model Example: Timoshenko Beam Bonded Particle Model
User: "Stephen Cole"
Altair Employee
Updated by Stephen Cole
Overview
Here you can find the documentation and example model of the Timoshenko Beam Bonded Particle Model. This novel bonded contact model is based on the Timoshenko beam theory and has been developed by the University of Edinburgh in 2015.
The example guide details the response of a cemented granular material under loading and could be suitable for other materials such as concretes/rocks.
Reference Manual:EBPM_RefrenceManual.pdf
Example Case Documentation and Simulation Files: ExampleConcreteCylinder.zip
Compiled Library File and preference file: EdinburghBondedPartilceModel.zip
Time Step Calculation Docs: TimeStepCalculation.xlsx
Attached are some screenshots from the example case. These screenshots show the ‘Damage’ property (ratio of broken to initial bonds per particle), we can see the failure method of the structure from this case. The screenshots are taken at the peak force and just after.
Usage/Installation Instructions
To use please see the EBPM_RefrenceManual.pdf
1 - 5 of 51
    User: "satri"
    Altair Community Member
    Updated by satri
    I dont see the API code in the zip file? is the API code available for this?
    User: "satri"
    Updated by satri
    Is the API code available for this model? Please let me know.
    User: "satri"
    Updated by satri
    Please let me know if the API code is available for this model
    User: "satri"
    Updated by satri
    Is there API code available for this model? Please let me know
    Altair Employee
    OP
    Hi Shyam,
    We don't have the API code for this, it is managed by the authors at Edinburgh University.  I'd recommend contacting Dr Morrissey to discuss access - https://www.eng.ed.ac.uk/about/people/dr-john-morrissey
    Regards
    Stephen
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
