Export Automatically CSV File of the Result Value for All Situation (Query All Ver3.0)
Overview
When you get queries of many subcases or of many result types, you should change contour and go to Query panel, change contour and go to Query panel, repeat it many times. This script helps it. By using this script, you can get all requested queries with one operation. - Release Note Update3.0 *Add Function: to export the additional information, which is the entity's coordinate, to csv file add the buttons to select all simulation step, or to remove all simulation step 複数のサブケースや複数の結果タイプのクエリを一括で行うことができます。 - リリースノート Update3.0 *追加機能: "座標値"をCSVファイルに出力する機能を追加 Simulationの一括選択、一括削除機能
Usage/Installation Instructions
Please road mvw file or run tcl (TopLevelMain.tbc) file. See my video, http://screenr.com/8LH8 こちらのビデオをご覧ください。http://www.screenr.com/CLH8.
Functionality
Results
Subfunctionality
Contour
Interface
No Specific Interface
