Script for computing the temporal evolution of the Lacey mixing index for a binary mixture of particles in EDEM
User: "Stefan Pantaleev_21979"
Altair Employee
Updated by Stefan Pantaleev_21979
Overview
This python script computes the temporal evolution of the Lacey mixing index [1] for a binary mixture of particles in EDEM from the mixture component mass fractions in a dense grid of rectilinear sampling bins as described below.
An example result from the script is shown in Figure 1. A value of zero corresponds to the perfectly segregated state and a value of one to the randomly mixed state. In addition to the graphs shown in Figure 1 the script outputs the results in a comma delimited text file.
Figure 1 a) Dense grid of rectilinear bins for the calculation of the Lacey mixing index and b) the temopral evolution of the Lacey mixing index.
[1] Gu, Z. and Chen, J. J. J. (2015) ‘A probabilistic analysis of some selected mixing indices’, Chemical Engineering Research and Design. Institution of Chemical Engineers, 93(April), pp. 293–303. doi: 10.1016/j.cherd.2014.04.014.
Pre-Requisite
EDEM 2022.3 and EDEMpy 1.2.0
Usage/Installation Instructions
The settings of the script are contained in the Lacey_settings.txt file and defined in Figure 2.
Figure 2 Inputs for the Lacey mixing index script
The python file can be executed directly from the EDEM Analyst using the Run EDEMpy script feature (File->Run EDEMpy script). The EDEM deck files, Lacey.py file and Lacey_settings.txt file should all be in the same folder. The script will find and post-process all EDEM decks in the folder that it is in and output the results in the same location.
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
