🎉Community Raffle - Win $25
Join and Win
Synctools: Tools Dealing With Comps/props/mats Rename/renumbering
Overview
This tool bar provides several functions which help to fulfil naming conventions and to synchronize names and ids of comps/props/mats. renumber/rename props by copms, mats by props and vice versa add and truncate trailing or leading strings from name create props to existing comps create comps per prop (useful using direct property assignment) export and reimport of name/id relation
CURRENT VERSION:
240830 (August 2024) on nextGen GUI as Extension
22.01 (August 2024) on classic GUI
Usage/Installation Instructions
Just call the script e.g. by using the button on the scripting toolbar. A new tab on the browser area appears with all available functions.
Limitation
This tool has been developed satisfying customer requests, so some tools support only a small number of solvers and can be easily enhanced if necessary.
Use according attached version on nextGen or classic GUI.
Functionality
Model/Analysis
Subfunctionality
Model Setup
1 - 2 of 21
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
