CAD to Simulation
Overview
Part Browser - BatchMeshing Sheet Metal Parts
- Use of Part Browser to create part set
- Save CAD representation
- Create user representation with required PARAM / CRITERIA files
- Create representation send to Batch Mesher for meshing the sheet metal parts
Mid Mesh workflow for cast / plastic components
Connectors Creation - Welds and Bolts
- Using the Control Manager- Define controls to create the required type of connections.
- Use the create Tool to create – point/line/fastener/area connectors.
- Connector browser all features available within the browser.
Create Subsystems using the subsystem browser , like include files along with the connection files between the systems
Analysis Setup and Results Visualization
- Load collectors for SPC’s are created
- Load steps inputs – for Modal analysis – EIGRL card created
- Load Step creation – Normal modes
- Export the deck which has the subsystems and the connection subsystem and submit the file for analysis
- Load result *.h3d file in HyperView for result visualization – Modal frequency and mode shapes
Pre-Requisite
Should have the latest version of HyperWorks HW2022.2
Usage/Installation Instructions
Unzip the attached files to use for exercise as described in the videos on the Altair How to Channel - https://www.youtube.com/watch?v=IAlbncJYheA&list=PLGNemB0NFb0DYHM6UytxyTnLFdR_tNbZG&pp=iAQB
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
Hi Sudeep,
I guess the model is not uploaded.
