Altair RISE
Nominate Yourself Now!
material card for plastic
User: "VAL1"
Altair Community Member
Updated by VAL1
If I use plastic material, which meterial Card image should be used instead of MTA1?
1 - 5 of 51
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi naoki,
    You can use MATS1 card.
    Thank you
    User: "VAL1"
    OP
    Updated by VAL1
    Thank you for early reply.
    If I check the MATS1,  what should I input TID, H,YF, Type=Plastic?
    User: "VAL1"
    OP
    Updated by VAL1
    Card Image remains MAT1. is it OK?
    Altair Employee
    Hi,
    Yes,  it is OK with MAT1,
    If you have stress-strain curve, use TABLD1 to input the curve value via TID,
    or if you have hardness values, use H, YF etc...
    User: "VAL1"
    OP
    Updated by VAL1
    Thank you!
    I could solve this.
