If I use plastic material, which meterial Card image should be used instead of MTA1?
Hi naoki,
You can use MATS1 card.
Thank you
Thank you for early reply.
If I check the MATS1, what should I input TID, H,YF, Type=Plastic?
Card Image remains MAT1. is it OK?
Yes, it is OK with MAT1,
If you have stress-strain curve, use TABLD1 to input the curve value via TID,
or if you have hardness values, use H, YF etc...
Thank you!
I could solve this.
