error 1000
Updated by Altair Forum User
1 - 6 of
61
thank you for your response
i use PSOLID property and i when assign my property, and run analysis i have this message : http://cjoint.com/?ECuorLESCgI
Hi,
Assign material to the property/component and run the analysis.
Hi,
The message is referring to quality of elements. If you are not bothered about the element quality you can stop checking element quality using Control cards>> PARAM>> CHECKEL>> NO
Hi Prakash Pagadala
thank you for your help , i resolve my error , but i have this new message : http://cjoint.com/?ECynJwZOW6ucan you help e please
thanks
Hi jeunehomme
Looks like you have not assigned a property to element(s) or assigned an in-compatible property.
Please check this.
PSOLID property should be applied to tetra elements. If you have applied PSHELL, it is not a compatible property for tetra elements.
