hi
i have this errors
help me please
Hi jeunehomme
Looks like you have not assigned a property to element(s) or assigned an in-compatible property.
Please check this.
PSOLID property should be applied to tetra elements. If you have applied PSHELL, it is not a compatible property for tetra elements.
thank you for your response
i use PSOLID property and i when assign my property, and run analysis i have this message : http://cjoint.com/?ECuorLESCgI
Assign material to the property/component and run the analysis.
Hi
i do your advice and i get a new message :
http://cjoint.com/?ECxoqZr70NF
The message is referring to quality of elements. If you are not bothered about the element quality you can stop checking element quality using Control cards>> PARAM>> CHECKEL>> NO
Hi Prakash Pagadala
thanks
