🎉Community Raffle - Win $25
Join and Win
Error on license file autentication
Good night,
I am having a problem with my license, it shows up this message when trying to open Inspire:
[03/01/21 21:41:29] System Error: No Auth Token in HHWU Config
[03/01/21 21:41:29] Trying activate features...
[03/01/21 21:41:29] Trying to activate...
[03/01/21 21:41:29] Activating...
[03/01/21 21:41:29] Activate required features
[03/01/21 21:41:29] System Error during checking out: Altair License Manager: License error
Feature(s): GlobalZoneEU, HyperWorks, HWInspire
Error Code: 9
Error Description:
Feature not found
Feature: Inspire
Error Code: 9
Error Description:
[LOCAL] C:\Program Files\Altair\altair_lic.dat - (Err: 9) Feature not found
License Path: C:/Program Files/Altair/altair_lic.dat;C:\Program Files\Altair\altair_lic.dat
Feature(s): GlobalZoneEU, HyperWorksEDU
Error Code: 9
Error Description:
Feature not found
Feature: HyperWorksEDU
Error Code: 9
Error Description:
[03/01/21 21:41:29] Failed to activate
And this one when trying to open hyperworks:
[03/01/21 21:44:19] System Error: No Auth Token in HHWU Config
[03/01/21 21:44:19] Trying activate features...
[03/01/21 21:44:19] Trying to activate...
[03/01/21 21:44:19] Activating...
[03/01/21 21:44:19] Activate required features
[03/01/21 21:44:19] System Error during checking out: Altair License Manager: License error
Feature(s): GlobalZoneEU, HyperWorks, HWHyperMesh
Error Code: 9
Error Description:
Feature not found
Feature: HyperMesh
Error Code: 9
Error Description:
Feature(s): GlobalZoneEU, HyperworksEDU
Error Code: 9
Error Description:
Feature not found
Feature: HyperworksEDU
Error Code: 9
Error Description:
[03/01/21 21:44:19] Failed to activate
I have created the variable environment as it was told in the email.
Hope to have your help as soon as possible.
Thank you.
Diogo Vicente
1 - 5 of 51
    What type of license file do you have? Are you able to share your license file here.
    Based on what type of license you have I can help you out.
    Hi,
    I have the exact same problem with my local student license file and Inspire 2021 installed on a PC in my University.
    However, I follow the steps described in this page and created the system environment variable, but the problem remains.
    Can you help me as soon as possible ?
    Kind regards,
    Lionel
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    Use windows folder options / view > display file name extensions, to make sure the file is named altair_lic.dat and not altair_lic.dat.dat,
    You need to confirm if the Ethernet address in the license file is the correct one and matches the one in your machine.
    When you open the license file in a text editor you will see an Ethernet address there in a line that says "ETHERNET =
    The Ethernet ID is the ID of your machine which is exactly 12 hexadecimal numbers. For example D4WRF478F398
    Run ipconfig/all in command window and check for physical address under Ethernet adapter local area connection:
    The listed physical address under Ethernet adapter local area connection should be used to generate the license file, if there is no listing of Ethernet adapter local area connection, the address under Wireless Adapter LAN Wifi must be used.
    That means if the address provided as above does not match the one in the license file, please request for the license file again with the correct Ethernet ID here https://studentedition.altair.com/
    Hi, Rahul and thank you for your answer.
    I checked the filename of the license file and it is good.
    The same for my MAC address : it is the good MAC address wrote in the "altair_lic.dat" file, but the problem remains.
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    I have written an email to you, please get back to us by email with your entire Ipconfig/all output from your command prompt.
