Altair RISE
Nominate Yourself Now!
LOADADD for SPCD load after pretension in non-linear analysis with contact
User: "Wesley_Peijnenburg2"
Altair Community Member
Updated by unknown
Hello experts,
I'm looking for advice on how to properly use LoadAdd for these different load types. The documentation states "SPCD load SIDs cannot be referenced by LOADADD data". Still, combining a pretension force with fixed displacement is desired here. So a simple cube with friction surface is created to check what is possible. A single element block pushes on the plate, then the plate moves sideways:
image    image
Two variations of the above model (optistruct solver decks) are attached:
   - "SPCD_Sub2.fem" > SPCD is applied in subcase 2 (via Loadadd). This doesnt work in subcase 2 (the plate does not move).
   - "SPCD_Sub1_and_Sub2.fem" > The same SPCD is referenced in both cases (first one directly, second one via loadadd). It works in both subcases as shown in the graph below.
Graph showing reaction (friction) force as function of plate displacement:
Question:
The expected (and desired) behavior in "SPCD_Sub2.fem" is first pretension, then displacement in a separate subcase. However I can only get it working if the SPCD is active in both of them. Is there a proper way to separate the different loads to have Sub1 with only pretension and Sub2 with only SPCD added on top of that pretension?
1 - 4 of 41
    User: "Rajashri_Saha"
    Altair Employee
    Updated by Rajashri_Saha
    Hi Wesley,
    I just went through your study and understood that in 1st step you want to push the block by applying force in Y-dir and in 2nd step you want to continue from 1st and along with that applying enforced displacement in -Z direction. You can do this by taking your 1st model  "SPCD_Sub2.fem" and remove the loadadd collector, appy only "Loads_spcd". Attached is the updated file.
    When reviewed "SPCD_Sub1_and_Sub2.fem", you have applied enforced disp twice in 2nd loadstep.
    Thanks
    Rajashri
    OP
    Updated by unknown
    Hi Wesley,
    Thanks
    Rajashri
    Hi Rajashiri,
    Thanks for checking the model. I downloaded "SPCD_Sub2.fem" taht you provided and ran it, the results show that the force from step 1 fades to zero during step 2:
    However, the goal of this model is to keep the "pretension/force" from step 1 active and constant during step 2. I'm expecting to see a (mostly) horizontal line in the upper graph with only the first iteration ramping up to that constant value of 1N (10% friction force). Do you know a good way to do this?
    - Wesley
    OP
    Updated by unknown
    Hi Rajashiri,
    - Wesley
    Just got it working without the loadadd, however it requires the initial force to be duplicated into the second loadcase. See attached fem file.
    This is the desired behavior, but I am still wondering if copy pasting is the recommended way to do this?
    Altair Employee
    I think you got the correct work around, If the load needs to be active in 2nd step then you need to have it applied in 2nd step too.
