Altair RISE
Nominate Yourself Now!
Feko Linux License Problem with API
User: "Tim_22605"
Altair Community Member
Updated by Tim_22605
Hello everyone,
I get access to the education version of Feko from the Altair Marketplace (the installation file even named hwFeko2023.1_edu_linux64). I want to use the API and build an example. If I want to run the indoor_propagation example, I get a license error. I added a screenshot.
Error (2105): License Error! Cannot initialize license:
ERROR : 23.0 Feature WinPropSolver or HWWinPropSolver not found on license file
   Altair License Manager: License error
Feature(s): GlobalZoneEU, HyperWorksEDU
Error Code: 9
Error Description:
Feature not found
License Path: \home\jeske\2023.1-edu\altair\security\home\jeske\2023.1-edu\altair\security
Error Code: 9
Error Description:
Feature not found
I found old posts in this forum, that students cant use Linux Versions
https://community.altair.com/community?id=community_question&sys_id=cbe9af4cdb001190e8863978f496196f
https://community.altair.com/community?id=community_question&sys_id=ca76c43a1b2bd0908017dc61ec4bcb17
but i downloaded the version from the offical marketplace... Do anyone know If I cant use the Linux Version or its a problem with the license path?
Thank you and best regards,
Tim
1 - 2 of 21
    User: "Payal Pawar_20288"
    Altair Employee
    Updated by Payal Pawar_20288
    Hi,
    Are you encountering this license error only for this particular example, or are you experiencing the error with other examples as well? Could you try running some other basic examples and let me know if you are able to run them successfully? This will help us determine if the issue is specific to this example.
    User: "Tim_22605"
    OP
    Hi,
    the error was also shown with basic examples. But I solved my problem. I missunderstand the licensing. I tried to use my license at the linux system without deactivating the license on the windows system.
    The guide (in annex) helps me a lot.
