Hi Altair, after run radioss, there are no 'result' button, what is the problem?
Wong Cy
Wong Cy Altair Community Member
edited May 2021 in Community Q&A
Hi Altair, after run radioss, there are no 'result' button, what is the problem?image
Answers
  • Rahul_P1
    Rahul_P1
    Altair Employee
    edited May 2021
    HI,
    Can you send us the model file so we can run it at our end and check the settings in your file etc. ?
    also what you do see when you click on the view dropdown, do you see results there? you can also check the run directory for the .h3d file and open this in the open model and results option in HyperView.
Welcome!
Welcome!
