Hi Altair, after run radioss, there are no 'result' button, what is the problem?
HI,
Can you send us the model file so we can run it at our end and check the settings in your file etc. ?
also what you do see when you click on the view dropdown, do you see results there? you can also check the run directory for the .h3d file and open this in the open model and results option in HyperView.
