Altair RISE
Nominate Yourself Now!
Ale Material Indentation Model
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear Sir,
I am facing a problem with a material indentation problem with Radioss. The Simulation crashes due to negative volume in the element. Please could you check as to where i am going wrong?
Regards,
Praveen
1 - 6 of 61
    Altair Employee
    OP
    Hi Praveen,
    DId you check RADIOSS help?
    This is mainly due to high deformation of solid meshes. Fully-integrated brick elements are especially affected by this problem which may be caused by a bad interface behavior or bad material definitions. In any case, the use of co-rotational formulation is recommended to avoid bad shear deformation response.
    add /DT/BRICK/CST and check if that helps.
    Altair Employee
    OP
    Hi Prakash,
    tried with the /DT/BRICK/CST  card, the simulation crashes with the same error! I have attached the picsf(mysimulation.jpg) along with the message! I am not sure as to what changes i need to make in the model such that I can simuate this results (Expected results.jpgexpected_result.JPG.507417fac64c201ae83c4688db7b32f1.JPG813086258_mysimulation.JPG.11733125ed26acabdd256b24eb24a6dc.JPG)
    Altair Employee
    OP
    Hi @praveen.sridhar1991
    I will check and get back to you soon,
    Altair Employee
    OP
    Dear Prakash,
    any updates on the ALE Model?
    Regards,
    Praveen
    Altair Employee
    OP
    I couldn't able to solve it myself as solid are have much better for ALE,
    I am checking with Experts on the same and will get back to you soon,
    Altair Employee
    OP
    Hi @roybudha
    Can you try with type 18 contact instead of type 9 and check if that helps?
