error#2372
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
how to get rid of this error i'm using tetra 10 elements.and rbe2 rigids also
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2016
    Hi,
    Can you paste the entire error message or share the entire out file?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi,
    I found that it is due to some of 2D elements, but when i tried to tetramesh that it is showing that it is getting meshed but when i mask the 2Delements i'm finding that it is not getting meshed.How to do tetramesh for that parts??
  • Altair Forum User
    Altair Forum User
    Altair Employee
    for that parts it is showing as 11000 elements are outside of mesh volumes and discarded and how to deal with self intersection of parts?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi jahnavi,
    check if there are any intersections in the 2D mesh and try to remesh without any intersections.
    Using the new mesh, do a tetra mesh.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    hi prakash,
    can u please tell me what are different ways to deal with intersection
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi,
    Go to Tools page>> Penetrations and Intersections>> check for intersections and try to remove them automatically.
    If you still see an issue with meshing, share the file with us.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    can u pls share the mail?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Jahnavi,
    Use the LINK to share the file.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    hi,
    i sent it.thanku
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Jahnavi,
    Is this extracted through STL?
    I see lot of free edges and the model is not an enclosed solid. You need to work on closing the voids.
    Go to Tools>>Edges>> Find edges. You will see more than 100 free edges on your model.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    it was in .max file then i deleted solids and did tetrameshing
  • Altair Forum User
    Altair Forum User
    Altair Employee
    hi prakash
    the upper head part has no free edges but y it is not getting meshed
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Jahnavi,
    There are free edges at several regions. You need to repair these regions. does .max file writes elements or surfaces?
    If it is surfaces then it will be to correct.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    okay.I have imported it as elements and then i deleted solids in hypermesh
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Jahnavi,
    Were you able to fix the void regions in your model?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    hi ,
    some i could but some i can't in the head region there are no void but meshing couldn't be done.same is the case with ribs
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited December 2016
    Jahnavi,
    You may have to mesh it manually or use tetra elements.
    try to achieve a closed volume solid so that it will be easy for you to mesh.
Welcome!
Welcome!
