how to get rid of this error i'm using tetra 10 elements.and rbe2 rigids also
Can you paste the entire error message or share the entire out file?
I found that it is due to some of 2D elements, but when i tried to tetramesh that it is showing that it is getting meshed but when i mask the 2Delements i'm finding that it is not getting meshed.How to do tetramesh for that parts??
for that parts it is showing as 11000 elements are outside of mesh volumes and discarded and how to deal with self intersection of parts?
Hi jahnavi,
check if there are any intersections in the 2D mesh and try to remesh without any intersections.
Using the new mesh, do a tetra mesh.
hi prakash,
can u please tell me what are different ways to deal with intersection
Go to Tools page>> Penetrations and Intersections>> check for intersections and try to remove them automatically.
If you still see an issue with meshing, share the file with us.
can u pls share the mail?
Jahnavi,
Use the LINK to share the file.
hi,
i sent it.thanku
Hi Jahnavi,
Is this extracted through STL?
I see lot of free edges and the model is not an enclosed solid. You need to work on closing the voids.
Go to Tools>>Edges>> Find edges. You will see more than 100 free edges on your model.
it was in .max file then i deleted solids and did tetrameshing
hi prakash
the upper head part has no free edges but y it is not getting meshed
There are free edges at several regions. You need to repair these regions. does .max file writes elements or surfaces?
If it is surfaces then it will be to correct.
okay.I have imported it as elements and then i deleted solids in hypermesh
Were you able to fix the void regions in your model?
hi ,
some i could but some i can't in the head region there are no void but meshing couldn't be done.same is the case with ribs
You may have to mesh it manually or use tetra elements.
try to achieve a closed volume solid so that it will be easy for you to mesh.
