I want to do a topology optimization of a column considering the buckling problem. The column has a square cross section (90 x 90 mm) and has 3500 mm in height. Therefor I used shell elements with t=90 because I found out solids do not work for buckling issues in topology optimization. First I ran a simple linear buckling analysis which worked out pretty well. But when it comes to the optimization I dont know how to handle the buckling problem correctly. I used a non-zero base thickness for the shell elements and minimal compliance for the objective. When I set 'buckle' as a dconstraint with a lower boundary of 1.0, the constrains get badly violated. As another dconstrain I used a volumefracion of 0.9.
I dont know if I used the dconstraints correctly ... so does the response 'buckle' stand for the buckling load? I also read about 'LAMA' somewhere and found it in the 'constraint screen' but actually I am not sure how to handle this one properly.
Thanks for your responses in advance!
Regards
Nico
