What is the meaning and significance of Plastic strain (s) and von Mises (t) strain? What is the difference between the two?
Maybe : https://dianafea.com/manuals/d944/Analys/node405.html
Plastic strain is the strain in which the deformed body does not return to its original shape after the removal of the applied force. The plastic strain value is calculated by the solver whereas the von Mises strain is calculated by the HyperView. HyperView calculates the von Mises strain from the six strain components.
where:
, , represent the principal strains as calculated above for a strain tensor.
is the Poisson ratio set to a default value of 0.5.
