i have a strange Problem during toplogy optimization. The Problem formulation is : minimize mass, displacement constraint 0,4mm. The optimization converged, but the displacement in the graph oscillate in a very high range. (see the attached pic) And the displacement constraint is not respected by the solver.
what can i do to fix this?
Thank you very much
Regards
Andreas
