I have problem with my assembly,Since this is the first time im using this tool.I feel bit hard to find the options.
My problem is I need to close a gap between two components which is the 3Dmesh.
Can any one pls suggest me the solution
if the contact face is cylindrical or planar, I recommend to use Assembly|Align to project the nodes of one body on the other.
If the interface is whether cylindrical nor planar, you can use:
- Feature|Morph|Translate to move the face in the desired direction
- use FEM/Move Node to offset a face to close a gap.
