현재 PSIM을 학생 라이센스로 사용 중에 있습니다. gui. 파일을 이용하여 system을 통해 라이센스 스토어도 잘 뜨며 라이센스 활성화도 잘 됩니다. 알테어 온라인에 들어가 onprem에도 라이센스가 잘 발급되었음을 확인했습니다.
이후 PSIM 라이센스 셋업에도 path에 라이센스 스토어에 있던 라이센스 파일 위치(파란 글씨)를 잘 복사하여 붙였습니다. 그 뒤 다시 PSIM을 껐다 킨 뒤 ABOUT PSIM을 눌러 라이센스를 잘 읽고 있는지 확인해보면 라이센스가 정상적으로 뜨지 않습니다.(남은 날짜와 활성화된 라이센스 예를 들면, moter drive 등) 근데 또 어떨때는 라이센스를 읽기도 하고 못 읽기도 하는거 같습니다. 하지만 라이센스를 읽은거처럼 about psim에 떠도 시간이 지나면 라이센스를 못읽었다며 경고창이 뜨고 곧 닫힙니다. 원인을 모르겠습니다 도와주세요. I am currently using PSIM with a student license. Using the .gui file, the License Store launches correctly via the system, and license activation proceeds without issues. I also verified on the Altair online portal that the on-premise license has been successfully issued. Subsequently, I correctly copied and pasted the path to the license file (indicated in blue text in the License Store) into the PSIM license setup. However, after restarting PSIM and checking "About PSIM" to verify if the license is being read, the license information (such as remaining days and activated features like "motor drive") does not appear correctly. It seems inconsistent; sometimes the license is recognized, and other times it is not. Even when "About PSIM" initially displays the license information, a warning message stating that the license could not be read appears after some time, and the program closes shortly thereafter. I am unsure of the cause and would appreciate your assistance.
Hi
Please refer to the following guide (Step 3 and 4) for detailed instructions on installing and activating your Altair Student Edition software using your Student Edition license key - https://community.altair.com/discussion/34207/instructions-to-access-the-free-altair-student-edition-now-in-altair-one#latest Pls see this to review limitations of Altair PSIM Student Edition in the following discussion- https://community.altair.com/discussion/20011/issue-simcoder-components-are-constantly-disabled-student-license
You might find the following discussions useful - https://community.altair.com/discussion/comment/200137#Comment_200137
https://community.altair.com/discussion/20960/lisence-issue?tab=all&utm_source=community-search&utm_medium=organic-search&utm_term=Connection%20to%20the%20license%20server%20is%20lost.%20The%20application%20will%20shut%20down.
Thanks
