Good morning everyone,
I am currently working on the pre-processing of a tennis racket geometry. As you can see from the image attached, I would like to simplify the area around the hole by removing the fillets, as they are preventing a proper mesh generation and making the geometry too complex.
I have been using the Topology > Defeature > Fillets tool. The software correctly identifies the fillets and highlights them in red; however, when I click on 'Remove All', nothing happens.
Could someone kindly help me troubleshoot this issue? Thank you in advance for your assistance.
