Description: PSIM 설치를 위해 2026PSIM 설치프로그램을 설치하면 15,40 에러가 뜨고, 안내받은대로 라이센스매니저를 설치하면 라이센스파일을 넣으라고하는데 예전에 쓰던 라이센스는 그냥 알테어 아이디와 비밀번호로 사용했어서 따로 라이센스 파일이 없어요
Product/Topic Name : PSIM
Dear User, Is this regarding a student edition license? If so, to help us route your issue to the appropriate colleague, could you please add the “Student Edition License” tag to your post? This will ensure that the right team member can assist you more effectively.
Also, please note that the preferred language for support is English. If possible, could you repost or summarize your question in English? If this is a bout a paid license, please create a ticket in Siemens Support Center. This is our new Customer Support Portal.
Thank you for your understanding.
