Following up with below link, the given script files into .zip file shows an error for GETNAME line. Can you please share updated script for MOSFET(Eon). link:
Syntax Error:
Dear @Sunetra1052, The article you are referencing seems to be an outdated version. Here is the latest version:
Thanks for bringing this to our attention. I notified the uploader to remove the outdated version to avoid confusion. BR Nikos Dimitrakopoulos
Dear @Sunetra1052, Please make sure that you are using the latest PSIM version and the latest version of the scripts as attached in my previous answer. If the issue persists please specify which xml device you are trying to translate. We currently support Diodes, IGBTs and Mosfet (Eon) devices.
