I am a BEng (Hons) Civil Engineering student conducting research on the structural robustness of existing buildings through roof-level retrofitting. Using S-FRAME, my work focuses on modelling a roof-level retrofit beam, its anchorage to the 1st and 2nd floors, and the simulation of a ground-floor column removal scenario. While I am able to successfully remove the ground-floor column, I am currently unable to model the roof-level retrofit beam and its anchorage to the lower floors. I would appreciate your guidance and support on this aspect. The relevant research papers and supporting documents are attached for reference.
Hello Tanveer3, thank you for your message.
We appreciate the documentation and the information provided, we believe that this might be best discussed through a technical support case were you could share the model you are having issues with and we could further discuss the requirements of your simulation.
You can create one by following the instructions on this article, this will provide the fastest response time
We look forward to hearing back from you,
Best regards.
