I noticed that the results from the same models with coupled solution and the structural solution with mapped temperature and pressure are different(from pdf of heat transfer analysis training), is it because that within the coupled solution, the displacements of the model will be sent to flow solver to recalculate the result and the pressure data will be sent to structural solver as well(meaning there are feedbacks between two solvers)? If it is so, does it mean that the coupled solution has more accurate result only that is costs more?
