Hello Team,
I want to understand about simulation of Bolt loosening judgement using Hypermesh.
How we can check either bolt will be loosen or not ?
Thanks & Regards,
Aman Yadav
JBM R&D
7898916272
Hi Aman,
Usually bolt loosening will happen due to vibration and fatigue. In FEA, you can check the contact status as well as drop on pre load.
I am attaching a good document for your reference.
Hello Rajashri,
Thankyou for useful information .
Is it possible to connect with you , so that I can show you my issue .
My contact 7898916272
email : aman.yadav@jbmgroup .com
You can create a support ticket to look into the issue in more detail.
