I need to perform the welding distortion in the structure. Could you please suggest potential solutions to proceed further?
Hi you can refer the example file(RD-E: 4802 Solid and Spring Spotweld in Crash Box)
from Radioss help document.
https://2024.help.altair.com/2024.1/hwsolvers/rad/topics/solvers/rad/solid_spotweld_example_main_r.htm
Regards
Harish
Hi you use either OptiStruct or Radioss. In both solvers, the material failure criteria are available,
Bae ine types of welds we recommend, like seem weld or spot weld.
Hi @HarishT ,
Can you please send the simulation procedure or sample problem to know how to carry out the weld distortion simulation?
Hello Naresh,
The FEMFAT have an extensive weld module to analyze the spot, seam, and solid weld failures. it effective predicts the crack initiation/material failures.
For more information, pls visit FEMFAT Software - Engineering Center Steyr - FEMFAT Software
Thanks,
Rajivgandhi Kaveri
