Hi all!
My problem is as follows. I am trying to run the ACU-T:6102 Windshifter tutorial that couples EDEM with SimLab.
I have AcuSolve, SimLab, and EDEM all version 2024.1. Whenever I follow the tutorial steps and right-click Results under Coupled Solution in EDEM to Update Results, instead of an orange result button, mine stays red, showing no indication that the solver starts. Additionally, I am not able to right-click Results and show the solver log — for me it only shows the option to Update again.
EDEM does start to run correctly and particles are generated. After the total simulation time (1s), the simulation in EDEM finishes and I can see the results in EDEM. However, in SimLab there is still no indication of results and I am not able to do any post-processing. The mesh and setup window remain visible.
When I right-click Results → Update, the output window shows:
Exported Unit System : MKS (m kg N s)
AcuSolve export completed.
However, there is no indication (as in the tutorial) that says Started Solving Coupled Solution.
I have checked the working directory and reviewed the Flow.1 log. To my knowledge, AcuSolve does run correctly.
Another strange thing is that, even after stopping after 1 second, the EDEM Total Simulation Time automatically jumps to a very large number. Also, during solving, the progress bar in EDEM remains at 0%.
Now to make things more complicated: I previously (2–3 months ago) successfully ran coupled simulations using EDEM and SimLab, with solver logs and post-processing working correctly. Later, I uninstalled SimLab and AcuSolve to free up space for Ansys Fluent. After reinstalling SimLab and AcuSolve, this problem began.
At one point, during a SimLab uninstall, my PC crashed. I cleaned everything carefully and reinstalled SimLab. When installing SimLab back under \Altair\2024.1, it would silently crash on startup. I then reinstalled SimLab in a different folder: \Altair\Simlab_clean, and now it opens fine. I am confident that the uninstalls were clean and that the current installs are clean. Also, there is only 1 version of each and I have always removed all files on my system regarding previous versions.
I do not think this SimLab folder change is related to the problem with results not showing, as I had this problem also before when everything was under the same \Altair\2024.1 folder, but I wanted to mention it.
Can anyone help me fix this? I have tried everything I can think of. Whatever I do, if I update Results in SimLab it does not show that it is solving. No results are loaded into SimLab and nothing is available for post-processing. Acusolve and EDEM do seem to work fine.  I have tried reinstalling and that does not seem to help.
Thank you so much.
Jan-Thijn Wijnker
