Hi Good Day!
I have an air blower model, and I want to perform an analysis to determine the sound levels at the inlet and outlet.
Before working on the actual case, I’d like to start with a simpler scenario — air flowing through a pipe.
Let’s consider a 1-meter pipe, where I know the mass flow rate at the outlet and assign the stagnation pressure at the inlet.
Using this example, could you guide me on how to set up the analysis in AcuSolve with SimLab? Also, is any co-simulation required for this, such as involving AcuSolve with OptiStruct or other tools?
Additionally, if there are any best practices or similar tutorials available for this type of analysis, I would greatly appreciate if you could share them.
Thanks & Regards,
Sivaprakash V.
