Description: I'm trying to get up to speed with the 2024 version of OptiStruct, having previously used older versions. In the past, when applying constraints, I could apply SPC by selecting a surface, and then mesh the surface later. Now using 2024, the selector only seems to let me choose between nodes and sets and I can't see to select a surface for applying SPC (in the Select Nodes selector, I see that I change pick "By Surface" but in the absence of nodes that doesn't seem to do anything. Is it no longer possible to apply constraints to geometric entities prior to meshing?
Product/Topic Name : HyperMesh 2024 - OptiStruct
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
