Hello everybody,
I've been trying to run a basic simulation for an impact attenuator made out of a flax STACK laminate with material card ID MAT25_COMPSH and property with card ID: P17_Stack.
I've tried several different parameters but no matter what I do the simulation animation results in a ductile failure instead of being brittle. At the same time DAM1, DAM2 and DAM3 are always 0 and the plastic strains are also 0, which doesn't make sense to me.
I've tried using Chang, Hashin and Puck failure criterion without any luck. I've also seen in a community post that from v2023 Hoffman, TSAIWH, TSAIHILL and MAX_STRAIN have been added, but when I open Hypermesh 2024 (I don't have the 2023 version, only 2022.3 and 2024) those failure criteria aren't showing.
I leave attached a sample .hm file of a baseline simulation (with a random geometry and laminate) as well as a picture showing the failure mode.
Any help would be more than welcome as I'm not sure what to do from now on,
Thank you so much :))
